A4200 Flexible Sealing Element
With the mounting of the flexible sealing elements in the mould cavity plates, inserted metal parts can be over moulded without flashing plastic or compession damage.
There is no comparable material on the market which can match the advantages of the sealing element A4200/... (MurSeal?ยต technology).
A4200/... is proven in practice!
The use of A4200/... has been proven successfully in the moulding of reinforced and unreinforced plastics. The machining of the flexible sealing elements A4200/... presents no problem with standard cutters used for steel.
A4200/... ?keeps sealed?
A4200/... opens up new dimensions where technology was previously at the limits of its capabilities: metal inserts are over moulded reliably without damage or flashing plastic. The number of rejects is drastically reduced. Particularly useful for sheet metal thicknesses from about 4 mm upwards.
A4200/... helps you to save money!
Through the elimination of reworking costs and the reduction of reject rates, unit costs can be lowered considerably.
The flexible sealing element A4200/... is available exclusively from HASCO!
