ARC: Inline multi-angle V-notch saw
Whereas the traditional method for rendering angled edges on post-extruded profiles is to use a miter saw offline, CDS's ARC (Angled Repositioning Cuts) saw is used inline to create the same result.
Whereas the traditional method for rendering angled edges on post-extruded profiles is to use a miter saw offline, CDS's ARC (Angled Repositioning Cuts) saw is used inline to create the same result. Powered by a servo motor and drive, the saw cuts at two preset angles, from 45 to 135 degrees, at one or both ends of a profile.Originally designed to cut window frames, the ARC saw is also suitable for cutting fence posts,fence panels, and other applications with angled edges. To access the brochure visit: www.cdsmachines.com/arc.pdf
