Bunting Intros New Machine-Mounted All-Metal Separator
Bunting Magnetics Co. has introduced a new Machine-Mounted Separator (MMS), which is an electronic metal detector designed for the plastics industry.
Related Suppliers
Bunting Magnetics Co. has introduced a new Machine-Mounted Separator (MMS), which is an electronic metal detector designed for the plastics industry. These Machine-Mounted Separators are engineered to sense and remove both ferrous and nonferrous metals – including iron, stainless steel, aluminum, copper, brass, lead, and tin – from moving virgin and regrind material. Compact, cube-shaped MMS units fit where headroom is limited, work with both gravity and pneumatic systems, and can be installed directly at the infeed of extrusion, injection, and blow molding machines. Their sturdy construction is designed to support the weight of hoppers, conveying components, mixers, and other equipment. By helping to prevent metal scrap from entering processing machines and contaminating final product, these separators reduce costly machine damage and downtime and increase overall production efficiency.
