Compact, Hot Runner Temperature Controller
Approximately 1/3 the size of standard mainframes, EMI’s new, compact, Temperature Controller is slim sleek and space efficient.
Approximately 1/3 the size of standard mainframes, EMI’s new, compact, Temperature Controller is slim sleek and space efficient. An easy to use control pendant adds flexibility and makes programming simple and fast. The mainframe is designed to stand alone, or be hung on the wall, which allows workspace to be used more efficiently. Connectors are located on the front panel, allowing the user to see all connections between the hot runner mold and the hot runner controller at a glance. A Soft Start control removes humidity in the system which helps to increase heater life. Size is approx. 16.5" wide, 9.2" long and 18.7" high
