by Scott M. Grendahl, U.S. Army Research Laboratory Aberdeen Proving Ground; and Ed Babcock, Stephen Gaydos and Joseph Osborne, the Boeing Co.
Solvent substitution for maintenance and overhaul operations of military systems has been a primary environmental concern for many years. Cadmium replacement in these systems has been targeted for decades. Both of these areas have a common obstacle for implementation of any potential alternate. Hydrogen embrittlement of high strength steel is the most predominant unforeseen hurdle since high strength materials show sensitivity to the phenomena and the source of the hydrogen can be anything within the fabrication process, maintenance practice or the natural corrosion cycle. Standardized testing on this issue has traditionally stemmed from the aerospace industry where it is a principal focus.
A design of experiment (DOE) approach was used over a range of material strength for both air-melted (AMS 6415) and aerospace grade (AMS 6414) 4340 steel, load level and hydrogen environment. Five ASTM F-519 geometries were explored while monitoring load levels to determine a precise time to fracture at a specific notch fracture strength (NFS), material strength and hydrogen emitting environment (NaCl solution). This allowed comparisons across geometry and material to be drawn. Incorporating the failure time, load and stress levels into the failure models yielded predictive equations over broad parameter ranges. Reliable predictions of hydrogen sensitivity under specific conditions were then realized.
Ultimately, this work aims at evaluating the most prospective environmentally-friendly maintenance chemicals and cadmium alternative coatings that have their use limited by the perceived risk of hydrogen embrittlement. In subsequent years, this work will evaluate the prospective chemicals and coatings over a range of material strength, load level and hydrogen emitting environment which will demonstrate hydrogen sensitivity over parameter ranges, while developing life prediction models for each case. This should greatly increase the applications for which the replacements will be considered, as the models provide the acceptability criteria for the parameters specific to each application.
Keywords: Hydrogen embrittlement testing, hydrogen embrittlement prediction, high strength steels.
• T2 = 158 ± 5 ksi (153-163 ksi)
• T3 = 210 ± 5 ksi (205-215 ksi)
• T4 = 262 ± 5 ksi (257-267 ksi)
• T5 = 280 ± 5 ksi (275-285 ksi)
• T2 = 75 + 6 tensiles
• T3 = 180 + 6 tensiles
• T4 = 75 + 6 tensiles
• T5 = 45 + 6 tensiles
Table 1 - Temper lot quantities.
Temper Lot No. | Strength Target, ksi | No. of specimens | |||||||
1a.1 | 1a.2 | 1c | 1d | 1e | Total | + | Tensiles | ||
T1 | 140 | 6 | 6 | 6 | 6 | 6 | 30 | + | 6 |
T2 | 158 | 15 | 15 | 15 | 15 | 15 | 75 | + | 6 |
T3 | 210 | 36 | 36 | 36 | 36 | 36 | 180 | + | 6 |
T4 | 262 | 15 | 15 | 15 | 15 | 15 | 75 | + | 6 |
T5 | 280 | 9 | 9 | 9 | 9 | 9 | 45 | + | 6 |
Condition | -α | ̶ | 0 | + | +α |
Strength, ksi | 140 | 158 | 210 | 262 | 280 |
Test load, %NFS | 40 | 45 | 60 | 75 | 95 |
NaCl, wt% | 1.25E-05 | 0.01 | 0.50 | 2.36 | 3.50 |
The design of experiment approach was refined with preliminary ruggedness and risk reduction efforts at Boeing Mesa, with technical assistance from Boeing St. Louis, Seattle, and ARL. Typical of DoEs, it consisted of three test portions, a linear portion, a quadratic portion and a confirmation portion. The example matrix is as presented in Tables 3 thru 5 with the condition values corresponding to Table 2. These experiments aided the development of appropriate boundary conditions for the larger effort.
Repeat entire matrix 2× for 1a.1, 1a.2, 1c, 1d and 1e | Run ID | A | B | C | Run order |
Strength, ksi | Test load, %NFS | NaCl, wt% | |||
Linear portion | L1 | ̶ | ̶ | ̶ | Random |
L2 | ̶ | ̶ | + | ||
L3 | ̶ | + | ̶ | ||
L4 | ̶ | + | + | ||
L5 | + | ̶ | ̶ | ||
L6 | + | ̶ | + | ||
L7 | + | + | ̶ | ||
L8 | + | + | + | ||
Center points | C1 | 0 | 0 | 0 | |
C2 | 0 | 0 | 0 | ||
C3 | 0 | 0 | 0 | ||
C4 | 0 | 0 | 0 | ||
C5 | 0 | 0 | 0 | ||
C6 | 0 | 0 | 0 |
Repeat Q1-Q6 5× for 1a.1, 1a.2, 1c, 1d and 1e | Run ID | A | B | C | Run order |
Not replicated | C7 | 0 | 0 | 0 | First |
Quadratic portion | Q1 | +α | 0 | 0 | Random |
Q2 | -α | 0 | 0 | ||
Q3 | 0 | +α | 0 | ||
Q4 | 0 | -α | 0 | ||
Q5 | 0 | 0 | +α | ||
Q6 | 0 | 0 | -α | ||
Not replicated | C8 | 0 | 0 | 0 | Last |
Confirmation portion | 1 | Varied, depending on outcome of Linear, Center and Quadratic Results | Random | ||
2 | |||||
3 | |||||
4 | |||||
5 | |||||
6 | |||||
7 | |||||
8 | |||||
9 | |||||
10 | |||||
11 | |||||
12 | |||||
13 | |||||
14 | |||||
15 | |||||
16 | |||||
After the linear and center point data runs were completed, initial calculations were made for the predictive model equations. Those initial models were utilized to choose confirmation runs to be researched. The confirmation run results were then incorporated into refining the initial working model.
As stated previously, upon conclusion of the linear, center and quadratic test runs, preliminary life prediction models were created. These models were then used in the confirmation test portion of the matrix to choose appropriate parameters to both enhance and verify the model. Final life prediction equations and three dimensional models were created after the incorporation of the confirmation data.
Air-melted SAE-AMS-6415 steel
1a.1 Preliminary Model
where
Offset = σ×ln(-ln(1-P)) (4a)
for which
T = time to event. It is either the time to failure or the time to the end of the experiment (168 hr).
P = the predicted percentile. At a P of 70%, 70% of the failures would be above the curve and 30% would fall below the curve generated.
σ = 1/Weibull shape parameter. Weibull shape parameter = 0.579.
- A negative value of the coefficient is indicative of a shorter lifetime as the variable increases.
- Weibull shape < 1 → hazard rate (failure rate) decreases as time increases.
- Infant mortality. After initial early failures the survival improves with age.
1a.1 Confirmation Model
ln(T) = 6.77-4.98×Str-1.29×Load-0.93×NaCl-3.66×Str×Load+Offset (5)
Weibull shape parameter = 0.567
1a.2 Preliminary Model
ln(T) = 9.09-5.49×Str-7.39×Load-1.39×NaCl+Offset (6)
Weibull shape parameter = 0.377
1a.2 Confirmation Model
ln(T) = 8.75-5.90×Str-6.53×Load-1.33×NaCl+Offset (7)
Weibull shape parameter = 0.397
1c Preliminary Model
ln(T) = 19.01-11.67×Str-9.93×Load-0.88×NaCl+Offset (8)
Weibull shape parameter = 0.343
1c Confirmation Model
ln(T) = 20.91-10.53×Str-11.30×Load-1.25×NaCl+Offset (9)
Weibull shape parameter = 0.278
1d Preliminary Model
ln(T) = 7.83-4.04×Str-3.54×Load-1.01×NaCl+Offset (10)
Weibull shape parameter = 0.515
1d Confirmation Model
ln(T) = 7.68-4.12×Str-3.08×Load-6.04×NaCl+Offset (11)
Weibull shape parameter = 0.546
1e Preliminary Model
ln(T) = 12.31-7.45×Str-6.45×Load-0.97×NaCl+Offset (12)
Weibull shape parameter = 0.505
1e Confirmation Model
ln(T) = 13.14-8.16×Str-6.58×Load-0.73×NaCl+Offset (13)
Weibull shape parameter = 0.493
Vacuum Arc Re-melted SAE-AMS-6414 steel
ln(T) = 5.20-4.79×Str-2.22×Load-1.73×NaCl-1.24×Str×Str+Offset (14)
Weibull shape parameter = 1.090
ln(T) = 5.66-5.28×Str-2.82×Load-1.52×NaCl-1.29×Str×Str+Offset (15)
Weibull shape parameter = 0.913
ln(T) = 7.90-5.20×Str-3.00×Load-1.77×NaCl+Offset (16)
Weibull shape parameter = 0.643
ln(T) = 7.69-7.73×Str-2.93×Load-1.57×NaCl-2.40×Str×Str+Offset (17)
Weibull shape parameter = 0.644
ln(T) = 11.35-8.27×Str-5.96×Load-3.2×NaCl-2.5×Str×Str+Offset (18)
Weibull shape parameter = 0.548
ln(T) = 11.6-8.19×Str-6.49×Load-2.92×NaCl-2.34×Str×Str+Offset (19)
Weibull shape parameter = 0.541
ln(T) = 6.63-6.85×Str-1.40×Load-0.95×NaCl-2.80×Str×Str+Offset (20)
Weibull shape parameter = 1.234
ln(T) = 6.52-6.58×Str-1.08×Load-0.99×NaCl-2.60×Str×Str+Offset (21)
Weibull shape parameter = 1.237
ln(T) = 9.08-11.04×Str-1.68×Load-2.21×NaCl-4.29×Str×Str+Offset (22)
Weibull shape parameter = 0.646
ln(T) = 8.92-9.56×Str-1.93×Load-2.18×NaCl-3.26×Str×Str+Offset (23)
Weibull shape parameter = 0.695
- Life prediction models were developed that accurately represent the expected hydrogen sensitivity over the range of parameters explored for air-melted and vacuum arc re-melted 4340 steel.
- The trends observed in the data were reasonably consistent across all test geometries. Sensitivity increases with applied load, material strength and to a lesser degree NaCl concentration.
- Applied stress has the most direct effect on hydrogen sensitivity, while material strength is a close second. Increasing the value of either parameter directly heightens the sensitivity to hydrogen.
- 4340 steel does not appear susceptible to hydrogen absorbed from environmental corrosion below the 160 ksi strength level.
- High residual stress levels (40-50% of UTS) are capable of causing hydrogen embrittlement without further applied system stresses.
- The 1d test geometry proved the most sensitive to hydrogen and also conducive to testing multiple specimens in various environments without requiring test load frames.
- Vacuum arc re-melted steel was more susceptible to hydrogen than air-melted 4340 steel in this environment.
- Vacuum arc re-melted steel was more sensitive to NaCl concentration than air-melted 4340 steel.
- SAE-AMS 6415S-2007, Steel, Bars, Forgings, and Tubing 0.80 Cr - 1.8 Ni - 0.25 Mo (0.38 - 0.43 C), SAE World Headquarters, Warrendale, PA, 2007.
- SAE-AMS 6414K-2007, Steel, Bars, Forgings, and Tubing 0.80 Cr - 1.8 Ni - 0.25 Mo (0.38 - 0.43 C) (SAE 4340) Vacuum Consumable Electrode Remelted, SAE World Headquarters, Warrendale, PA, 2007.
- ASTM F-519-10, Standard Test Method for Mechanical Hydrogen Embrittlement Evaluation of Plating/Coating Processes and Service Environments, ASTM International, West Conshohocken, PA, 2010.
- MIL-STD-870C, Department of Defense Standard Practice: Cadmium Plating, Low Embrittlement, Electro-Deposition, 2009.
Scott Grendahl has a B.S. degree in mechanical engineering - materials science from Worcester Polytechnic Institute and more than 20 years’ experience with U.S. Army Research Laboratory as a materials engineer. He became a team leader in 2007 and leads a self-sustaining research group of 10 people in metals integrity and sustainment research and development programs. He serves as ARL point for Army aviation sustainment research by AMRDEC/AMCOM, developing and leading the research efforts focused on resolving sustainment issues of critical importance to the fleet and serves as the ARL technical expert in hydrogen embrittlement, and as one of few ARL technical experts in surface enhancement technologies, failure analysis, coating technologies and corrosion. He leads environmental pollution prevention programs primarily pertaining to aviation systems. As a result of his experience in materials research, Mr. Grendahl has acquired expertise in a broad range of materials characterization, surface enhancement and processing techniques for metals, ceramics, polymers and composite structures. He is the Army representative on both SAE committee J and ASTM F07 on Aerospace and Aircraft. Mr. Grendahl has been the recipient of more than 30 awards and Army Official Commendations for excellence in conducting his research and development work for DoD. Additionally, Mr. Grendahl has published more than 50 ARL technical reports and mroe than 40 technical publications in open literature in the areas of sustainment, coatings, corrosion, failure analysis and related research.
Ed Babcock
Stephen Gaydos
