Hurco distributor Brooks Associates will exhibit the five-axis VM10Ui mill featuring Ultimotion technology for improved surface finish quality.
Click Image to Enlarge
Hurco distributor Brooks Associates will exhibit the five-axis VM10Ui mill featuring Ultimotion technology for improved surface finish quality. The milling machine features X-, Y- and Z-axis travels measuring 21" × 16" × 19" and provides XYZ rapids of 945 ipm. The integrated Hurco control supports both ISO/EIA NC programming and conversational programming.
The machining center is said to minimize the number of setups and eliminate scrap with verification graphics. Advanced smoothing algorithms enable improved surface finishes. A 20-station automatic toolchanger is standard.
Brooks Associates also will exhibit the Hurco TMM8i turn-mill.
