chemical foaming agents for pipe profile extrusion
Glass-Reinforced ABS/Nylon Debuts in Customized Control Panel Housing
Ineos Styrolution's Terblend N chosen by two premium agricultural utility vehicle manufacturers.
A line of ABS/nylon blends, sold under the Terblend brand, developed by Ineos Styrolution, Aurora, Ill., especially well-suited for the manufacture of economical interior automotive components where a matte surface finish that does not require painting is desirable., is gaining new applications According to the company, two manufacturers of premium agricultural utility vehicles were looking for a material for the housing of the control panels as an equipment variant in their machinery. User-friendly handling along with high-quality matte surface and excellent haptics were key requirements.
            Terblend N NG02 EF grade, an 8% glass-fiber-reinforced, UV-stabilized ABS/nylon blend which boasts enhanced dimensional stability, rigidity and high flowability was identified as particularly suitable. Despite the glass fiber content, this blend reportedly offers a high-quality surface with matte appearance and excellent haptics, along with a very low moisture absorbance in comparison to nylon. One of the two manufacturers opted for the use of the material in a second component which also contains a certain amount of a TPE. Says Ineos Styrolution’s global automotive sales director Christophe Ginss, “Apart from control panels, Terblend N NG02 EF is used for many automotive interior applications, for instance, defrost vents. Other blends of Terblend N are used for applications like loudspeaker grills, seat covers, or venting devices, depending on the respective requirements.”
Insert molding automation
Bole Machinery
Blending Revolution
Registration is on Us
pipe and profile extrusion chemical foaming agents
LKIMM
Windmoeller
Dover Clear
