Housing’s Faster Growth Could Boost Appliance Production
Appliances
Leading indicators suggest continued growth in appliances.
The real 10-year U.S. Treasury bond rate is a very important leading indicator for the housing market and the appliance industry. Changes in this key interest rate tend to lead the housing market by 14 months and appliance production by 24 months.
The nominal 10-yr Treasury rate remained quite low in February. In fact, it was below 2% for the second month in a row, which was well below the historical average of 6.4%. The real 10-yr treasury rate, which is the nominal interest rate minus the rate of inflation, was 0.59% in February 2015. This was the first time since February 2013 that the real rate increased from the previous month. And it was the first time since July 2013 that the real rate increased from one year before.
The reason the real Treasury rate increased from a year ago is that the rate of inflation has dropped dramatically. The annual rate of inflation was negative in the last two months, which hasn’t happened since October 2009. With very low inflation and a rising yield, it is likely that the real 10-yr Treasury rates will continue to increase.
However, given that the 10-yr Treasury rate leads housing permits by 14 months, the declining trend in the interest rate over the last 15 to 18 months is signaling significant growth in housing permits and new construction. February’s housing permits increased 8.8% compared with a year ago, the fastest month-over-month change since September 2014. On annual basis, housing permits have grown at an accelerating rate in the last two months. That has not happened since October and November 2011. Based on the previous decline in the real 10-yr treasury rate, housing permits should see continued accelerating growth in 2015.
Current appliance production levels still are significantly below any time since 1994. But appliance production has been growing since March 2013. This is significant because this is the first period of growth in appliance production since July 2003 to July 2005. The rate of growth has been consistently strong since early 2014. If the accelerating growth trend in housing permits pans out, then appliance production should see even faster growth in 2015. It’s possible that appliance production could grow at its fastest rate in nearly 20 years in 2015.
While much less of a factor in forecasting appliance production, it is important than appliance spending has been growing since early 2013. So far in 2015, appliance spending has been growing much faster—the fastest in almost a decade. When growth in appliance spending is this strong, it can provide a boost to appliance production even if housing permits remain relatively weak.
So, the leading indicators seem to be pointing to continued strong growth in appliance production. And, if the housing market improves, then appliance production could grow quite rapidly this year.
Pregis Performance Flexibles: In the ‘Wow’ Business
Pregis went big and bold with investment in a brand-new, state-of-the-art plant and spent big on expanding an existing facility. High-tech lines, well-known leadership and a commitment to sustainability are bringing the “wow” factor to blown film.
Read MoreIn Sustainable Packaging, the Word is ‘Monomaterial’
Read More‘Monomaterial’ Trend in Packaging and Beyond Will Only Thrive
