Interesting Finalists of 2016 SPE Auto Innovation Awards
Take a look at these “runner-up” finalists in exterior, interior and chassis/hardware categories.
In two recent separate blogs (here and here) highlighting the award winners in nine categories of the 2016 SPE Automotive Innovation Awards, I noted that I would also highlight some of the finalists of certain categories that were particularly exceptional. Here are four such examples from the categories of body exterior, body interior, and chassis/hardware.
Exterior Body: Mold-In-Color (MIC) High-Gloss Body Color TPO Fascia. This component is featured on Ford’s 2017 Transit Connect and involved Advanced Composites’s ADX70004WFA TPO. Injection molded by Magna Exteriors, this MIC TPO fascia underwent rigorous testing to assure the material was resistant to stone pecking and road chemicals and would not change shape when exposed to high heat. Also used was a lens-grade mold with SP1 diamond polish and gating designed to minimize knitlines. The resulting fascia is a high-gloss, weather- and mar-resistant component. Moreover, it is 10% lighter, offers $800,000 annualized savings, and harmonizes with exterior painted components.
Interior Body: Thin-Wall Instrument Panel (IP) Substrate. Appearing on the Ford’s 2017 Lincoln Continental, this component is reportedly the thinnest full-size, deep-draw injection-molded IP in North America at 1.9 mm/0.07 in. A 30% glass-reinforced LFT-PP—Stamax 30YK270E, from SABIC was used and injection molded by Faurecia Interior Systems.
Compared to the 2.4 mm/0.009 in. microcellular foam-molded benchmark, this design is 14% lighter, saves over $1 in material cost as well as the microcellular-foaming investment, and helps optimize packaging. Moldfilling analysis with fiber orientation was used for accurate warpage predictions and to develop tooling countermeasures to facilitate part molding.
Chassis/Hardware: Rear Differential Cross-Member. This component appears on Daimler AG’s 2016 Mercedes S-Class and is said to be the first application where a nylon/glass composite has been used as a cross-member to support the rear differential and complete the rear cradle of a vehicle. BASF’s Ultramid A3WG10CR, a 50% glass-reinforced nylon 66 was used for the component which was injection molded by ContiTech North America. The material has been optimized for dynamic loads and is controlled with tighter production specs.
By replacing traditional parts in steel or aluminum, the injection-molded glass-reinforced nylon 66 design offers parts integration opportunities, is cost neutral, reduces noise transmission from the driveshaft, and reduces mass 25%, helping improve fuel economy and reduce tailpipe emissions.
What's the Allowable Moisture Content in Nylons? It Depends: Part 2
Tracing the History of Polymeric Materials: Acetal
The road from discovery in the lab to commercial viability can be long, and this was certainly the case for acetal polymers.
Prices of Volume Resins Drop
Price relief is expected to continue through the fourth quarter for nine major commodity and engineering resins, driven by widespread supply/demand imbalances.
