Cranes, Conveyors, Racks, Loaders, Accessories
New-Generation Rotational Rheometers
What are said to be radically new rotational rheometers for controlled stress/strain testing reportedly enable users to spend less time learning how to use the system.
What are said to be radically new rotational rheometers for controlled stress/strain testing reportedly enable users to spend less time learning how to use the system. Available from Malvern Instruments, Westborough, Mass., are the Kinexus pro, a high-end instrument for a wide variety of routine and research applications, and the Kinexus ultra for even the most demanding low-torque applications, such as weakly-structured and small-volume samples. Kinexus units reportedly incorporate technological innovations in the most critical areas of rheometer design, from sample preparation and loading to measurement setup and operation, to data analysis and reporting. Central to their operation is the rSpace intelligent software system that invites users to work at the level most appropriate to them. Also critical is the rMotion drive, a dynamically optimized motor that has a special adaptive air bearing that automatically configures its operation according to test conditions. In addition, newly designed environmental controllers and geometries for Kinexus are said to be truly “plug and play.”
Windmoeller
Registration is on Us
Insert molding automation
AM Workshop
Orbetron new for 2024 micro twin screw feeder
Vacuum Tech for Plastics Manufacturers
LKIMM
Make Every Pellet Count
Windmoeller
