NEW! LUXOR Series Beside the Press Dryers
Cost effective, reliable and easy to use, LUXOR dryers are available ex-stock with specifications to suit almost all applications.
Cost effective, reliable and easy to use, LUXOR dryers are available ex-stock with specifications to suit almost all applications. They can be quickly and easily installed on site, without a specialist's assistance. Thanks to a consistent pre-drying to a defined residual moisture, production crisis may be eliminated and a high quality assurance is achieved. No rejects due to humidity.
DRY AIR GENERATOR. All models have twin high capacity desiccant beds to ensure continuous drying. The desiccant cartridges are made of stainless steel. The models LUXOR 50 and 80 are fitted with a single process blower for production of dry air for both the process and regeneration circuits. The LUXOR 120 and 160 models have separate process and regeneration blowers. All models dry in a closed loop mode and operate with an extremely low dew point. A dew point indicator, aftercooler and high temperature version are standard options available across most of the range.
EFFICIENCY and FLEXIBILITY. Motan's LUXOR dryers operate at maximum efficiency and with minimum operating maintenance. The opportunity to have multiple material bins connected to one dry air generator provides our customers with maximum flexibility and no interruption to production. Drying can continue while material is changed in any one bin, minimizing loss of valuable production time during material changes.
CONTROL/OPERATION. Simplest handling by modern microprocessor controls. Indicators on the operating panel show the status of the dryer. Each drying bin temperature can be individually set at the bin.
DRYING BINS. Drying bins are fully insulated with individual heaters and temperature setting controls. The cylindrical shape ensures uniform drying. Bins are available in a range of sizes from 15 to 600 liters. Larger bins have an inspection door for ease of access and all are fitted with a sight glass. Bins can be machine mounted on mobile frames. A flange for mounting a Motan hopper loader is provided on all bins.
MODULARITY. All units, dryers and bins, are mounted on castors for ease of movement. The combination and quantity of bins installed to each dryer can be adapted at a later stage as operational requirements change. A small footprint means that LUXOR dryers and bins occupy minimal space on the factory floor.
