Newly Redesigned HF-2 Series Heat Transfer Fluid System
Mokon announces the availability of the newly redesigned HF-2 Series Heat Transfer Fluid System, updated with improved performance, energy efficiency and reduced space requirements for large flow and higher heating capacity applications.
Mokon announces the availability of the newly redesigned HF-2 Series Heat Transfer Fluid System, updated with improved performance, energy efficiency and reduced space requirements for large flow and higher heating capacity applications. The system provides accurate temperature control up to 600 degrees F.
The HF-2 Series features a 12 kW heater canister mounted in the traditional Mokon "horizontal forced fluid flow" design, proven in Mokon systems for over 50 years. This heater design, along with an all-welded construction, reduces internal piping and limits potential leak points. The system also features Mokon's uniuque "continuous flow" cool oil reservoir design to ensure accurate and safe process temperature control and cooling.
Mokon's HF-2 Series systems are available in single and dual zone configurations, pumping capacities of 40, 60, 90, and 120 gpm, and various heating capacities up to 144 kW.
