Electric Based machines for high speed/thin wall applicationsOptimum reliability from high performance actuators, eliminating expensive servo valves & oil contaminationOptimum energy efficiency (up to 60% in some applications)Reciprocating and Two-Stage Injection units availableWide range of shot sizes, extruder sizes, pressures & injection rates for optimum performance with maximum efficiencyStack mold capableGreaseless tie bar design utilizing linear bearing guidance systemOptional Greaseless Smartline stack mold center carrier systemNew “Walk-UP” base design allows easy access to high cavitation tooling
- Electric Based machines for high speed/thin wall applications
- Optimum reliability from high performance actuators, eliminating expensive servo valves & oil contamination
- Optimum energy efficiency (up to 60% in some applications)
- Reciprocating and Two-Stage Injection units available
- Wide range of shot sizes, extruder sizes, pressures & injection rates for optimum performance with maximum efficiency
- Stack mold capable
- Greaseless tie bar design utilizing linear bearing guidance system
- Optional Greaseless Smartline stack mold center carrier system
- New “Walk-UP” base design allows easy access to high cavitation tooling
