Low Friction ClampingRack and pinion clamp driveReplaceable die locating ringBull gear for die height adjustmentHighly sensitive Mold Guard protectionLow friction adjustable clamp shoes with outboard supportGreaseless tie bar design with low friction linear bearing clamp guidesChrome-Plated hardened steel toggle pins and reduced lubrication bushingsClamp lubrication alarmsAutomatic electrically activated die height adjustmentAuto lube of toggle linkagesDigital set-up and read-out of clamp position to 0.001” resolutionManual mold purgePneumatic mold gate (software/signals only)Tri-directional part removalWalk-up base design for easy access to high cavitation molds
- Rack and pinion clamp drive
- Replaceable die locating ring
- Bull gear for die height adjustment
- Highly sensitive Mold Guard protection
- Low friction adjustable clamp shoes with outboard support
- Greaseless tie bar design with low friction linear bearing clamp guides
- Chrome-Plated hardened steel toggle pins and reduced lubrication bushings
- Clamp lubrication alarms
- Automatic electrically activated die height adjustment
- Auto lube of toggle linkages
- Digital set-up and read-out of clamp position to 0.001” resolution
- Manual mold purge
- Pneumatic mold gate (software/signals only)
- Tri-directional part removal
- Walk-up base design for easy access to high cavitation molds
