All-ElectricHigh performance inject rollerscrewLow inertia direct drive traversing injection platens on and package units (electric units only)Laser aligned assembly procedureInjection unit swivel (reciprocating units only)Purge GuardScrew recovery time monitorTransfer to pack on position, volume, melt pressure, or timeDigital set-up and read out of inject position to 0.001” resolutionLow inertia pulleys on two stage unitsTwin pull-in cylindersHopper slide shutoff with discharge chutePrecision ground linear bearing sled carriagePoppet check on electric two stage units; Ball check or slider ring on reciprocating unitsInjection before tonnage (Pre-Inject)Global barrier screw design and nitride barrels on 2290 frame electric reciprocating unitsHybridHigh performance injection plunger with accumulator assistNozzle shut off valve included with hybrid accumulator injection unitLaser aligned assembly procedurePurge GuardScrew recovery time monitorTransfer to pack on position, volume, melt pressure, or timeDigital set-up and read out of inject position to 0.001” resolutionTwin pull-in cylindersHopper slide shutoff with discharge chutePrecision ground linear bearing sled carriageInjection before tonnage (Pre-Inject)
Click Image to Enlarge
All-Electric
• High performance inject rollerscrew
• Low inertia direct drive traversing injection platens on and package units (electric units only)
• Laser aligned assembly procedure
• Injection unit swivel (reciprocating units only)
• Purge Guard
• Screw recovery time monitor
• Transfer to pack on position, volume, melt pressure, or time
• Digital set-up and read out of inject position to 0.001” resolution
• Low inertia pulleys on two stage units
• Twin pull-in cylinders
• Hopper slide shutoff with discharge chute
• Precision ground linear bearing sled carriage
• Poppet check on electric two stage units; Ball check or slider ring on reciprocating units
• Injection before tonnage (Pre-Inject)
• Global barrier screw design and nitride barrels on 2290 frame electric reciprocating units
Hybrid
• High performance injection plunger with accumulator assist
• Nozzle shut off valve included with hybrid accumulator injection unit
• Purge Guard
