Roll Stands
PTi offers several unique roll stand configurations that are used to produce thin thru thick sheet gauges (0.006-1.000 inch/0.15-25.0 mm) at narrow thru wide sheet widths (24-130 inch/600-3,300 mm). REVOLUTION® roll stands feature linear bearing guided roll actuation with direct acting cylinders positioned on roll shaft centers.
PTi offers several unique roll stand configurations that are used to produce thin thru thick sheet gauges (0.006-1.000 inch/0.15-25.0 mm) at narrow thru wide sheet widths (24-130 inch/600-3,300 mm). REVOLUTION® roll stands feature linear bearing guided roll actuation with direct acting cylinders positioned on roll shaft centers. TRIDENT® roll stands feature heavy duty pivot arms for roll actuation using a lever advantaged cylinder placement. REVOLUTION® is available in a vertical, horizontal and J-stack arrangement. TRIDENT® is only available in a vertical and J-stack arrangement. All PTi roll stands are available using either pneumatic or hydraulic roll actuation depending upon the application and roll loads required. AUTOGAP is a digital servo hydraulic roll gap positioning option with a repeatability tolerance of less than 0.001 inch (0.025 mm) and is only available in the REVOLUTION® design platform.
