Sheet Extrusion
PTi Makes Changes in Leadership Structure
Sheet Extrusion
Moves aimed at bolstering the future of  the sheet extrusion manufacturer.
READ MORE
Latest Sheet Extrusion Articles
VIEW ALL
Roll Stand is Compact, Flexible
Streamlined stack is joined by high-speed extruder; service cart for maintaining screws, dies and rolls; and other products.
Film Extrusion
Rohm, SABIC Combine on New Film, Sheet Unit
Called Polyvantis, new firm to be a global powerhouse in PC and PMMA extrusion.
Film Extrusion
Macro Names Anzini Tech Sales Manages for Southeast
Has worked in technical roles for leading processing companies in his career of 40+ years.
Thermoforming
OMV Technologies Gets New CEO
Non-Contact Control of Flat Dies, Adapters
More automation comes to flat die technology.
Plastics Recycling Latam
NPE2024: The Plastics Show
Windmoeller
Latest Sheet Extrusion News And Updates
Davis-Standard to be Systems Integrator for Novel EDI Flat Die
Die uses motorized lip-adjustment, said to be three to five times faster than heated-bolt adjustments.
Film Extrusion
Die-Service Cart Upgraded to Handle Screws, Chill Rolls
Processing Technologies International LLC has released its next-generation flat die servicing system, the uCAMS (Universal Cleaning Assembly and Maintenance System) Plus.
Sheet Extrusion
Die-Lip Adjustment System Relies on Motorized Actuators
Nordson will debut an automated lip adjustment system for its EDI extrusion and fluid-coating dies at the K 2022 trade fair.
Features a unique, compact design for sheet processors with very limited production floor space.
PTXPO
Roll Stand Offers More Automation, Process Control
Processors benefit from technical and bottom line advantages of the roll stand’s inverted-down, multi-roll design.
dies
System Allows Fast, Efficient Die Cleaning
Processing Technologies International LLC (PTi) has developed a die splitting cart called uCAMS (Universal Cleaning Assembly and Maintenance System). The system was designed with the goals of flexibility, ease, and operator safety in regards to maintenance and upkeep of an extrusion die.
LKIMM
pipe and profile extrusion chemical foaming agents
Dover Clear
Shell Polymers (Real)ationships start here ad.
Featured Posts
Compounding
Green’s the Theme in Extrusion/Compounding
The drive toward circular economy is requiring processors to make more use of PCR. Machine builders at K—across all extrusion processes—will be highlighting innovations to help them do just that.
Minimize Sheet Gauge Variation by Roll Design
‘Hour-glass’ sheet gauge can be avoided through a reverse-bending roll design that is out of patent and freely available.
Understanding Roll Deflection in Sheet Processing
Because of roll deflection, sheet stacks made for PS don’t work nearly as well with PP. One solution is to try a top roll that bends in the opposite direction.
Sheet Extrusion
PPEs Are Here to Stay: Is Your Sheet Line Ready?
Follow these tips to evaluate your sheet extrusion lines to find out if you can expand into this market.
plant tour
Breaking Barriers: Sheet Processor Makes Move on High-End Packaging Market
Impact Plastics sets up new brand with game-changing disruptive technology that combines a novel PP with customized equipment that looks to upend the business of extruded sheet for barrier food packaging.
Improved Stainless 420 ESR
TracerVM Flow Meter features many display options
quick mold change solutions injection molders
Cranes, Conveyors, Racks, Loaders, Accessories
LKIMM
