New in PET: Injection-Compression-Stretch-Blow Molding
Continuous, rotary injection-compression molding of preforms is linked to rotary stretch-blow molding.
At November’s BrauBeviale show in Nuremberg, Germany, SIPA of Italy (U.S. office in Atlanta) has launched Xtreme Syncro, billed as the world’s first injection-compression-stretch-blow molding (ICSBM) system. It brings together SIPA’s Xtreme preform compression molding system with a high-speed stretch-blow unit.
As reported in our K 2013 show wrap-up last February, the Xtreme continuous, rotary injection-compression system reportedly produces preforms up to 10% lighter than any made by conventional injection molding, but without sacrificing key properties. Before now, the maximum length-to-wall-thickness ration (L/t) of a preform was little more than 45; but Xtreme technology is claimed to make an 80 L/t ratio a commercial reality.
Injection-compression simplifies thin-wall molding by having the molds slightly open when injection starts, then closing them as dosing finishes. This means lower injection pressure, lower clamp force, and less stress on the melt, which means less acetaldehyde (AA) generation and less reduction in IV.
Xtreme’s mechanical layout is similar to rotary stretch-blow machines. It is all-pneumatic, with no hydraulics. Molds are mounted in blocks of three on a high-speed carousel fed by an extruder that runs continuously. It delivers melt to dosing devices directly under the preform molds.
In the new system, preform molding is directly coupled to SIPA’s latest SFR EVO3 rotary reheat stretch-blow unit (also discussed last February), which can put out 2250 bottles/hr per cavity. The Xtreme portion alone is said to cut energy use around 10% through lower temperatures and pressures. And integration with the bottle blowing system eliminates most of the need to reheat the preforms. Conventional IR ovens are replaced by small ovens that use highly efficient induction heating directed only at areas of the preforms just below the neck. The system can also be connected directly to SIPA’s bottle filling system.
First Water Bottles With Ultrathin Glass Coating
Long used for sensitive juices and carbonated soft drinks, KHS Freshsafe PET Plasmax vapor-deposited glass coating is now providing freshness and flavor protection for PET mineral water bottles.
New PET Stretch-Blow System Saves Energy & Downtime, Aids rPET Use
New-generation Contiform PET stretch-blow molding machine from Krones is designed for sustainability throughout.
Krones Acquires Netstal
Krones adds PET preform injection molding to its bottle blowing and filling capabilities, as well as cap molding and expansion into medical, food and other markets.
