Twin-Screw Elements Offer Option to Kneading Blocks
Said to be less harsh while creating 'turbulent mixing' without stagnation.
Twin-screw compounding machine builder Steer introduced at NPE2015 a new series of screw elements that reportedly are suited to replace kneading blocks in certain applications.
Called Melt Formation Elements (MFEs), they will be used on Steer's Mega and Omega co-rotating twin-screw platforms to reportedly provide compounders with improved reliability, reduced wear and increased uniformity of melting and mixing.
Steers says the elements are designed to combat a series of problems faced by compounders of masterbatch, engineering plastics and difficult-to-process materials, notably: high wear; degradation during melting;  uncontrolled breakdown in the process and transmission section; and improper material flow causing pressure peaks, which in turn leads to shear peaks that create torque instability and re-agglomeration,
As Steer explains it, while conventional kneading blocks (right handed, left handed or neutral) are effective at dispersive mixing, they are too harsh for many applications. This is because they present a perpendicular face to the flow causing melt stagnation and large pressure and shear peaks during melting.
Notes Dr. Babu Padmanabhan, Steer's managing director & chief knowledge officer, “The MFEs are designed to create turbulence to the melt flow without stagnation.  They can replace conventional kneading blocks that suffer from lack of shear uniformity completely removing any right angled face to the melt flow.”
  • Sustainability Among the Many Niches at Niche Polymer
    Founded in 1987, Niche Polymer continues to grow—both organically and through acquisition—by focusing its product-development efforts on ever-changing market needs. Adding value to both industrial and post-consumer scrap is a growing part of this effort.
  • How to Configure Your Twin-Screw Extruder: Part 3
  • Configuring the Twin Screw Extruder: Part 4
AM Workshop
quick mold change solutions injection molders
pipe and profile extrusion chemical foaming agents
Plastics Recycling Latam
Windmoeller
Vacuum Tech for Plastics Manufacturers
Blending Revolution
