TWINcut - Screenless Granulators
Motan’s TWINcut beside the press granulator is ideal for granulating conventional plastics including glass filled materials as well as soft thermo plastic elastomers (TPE) and similar materials.
Related Suppliers
Motan’s TWINcut beside the press granulator is ideal for granulating conventional plastics including glass filled materials as well as soft thermo plastic elastomers (TPE) and similar materials. The TWINcut utilizes a two-shaft, patented cutter design. This unique two stage process progressively reduces the regrind particles down to an ideal size. - The first stage pulls the sprue/part into the cutting chamber producing a medium sized particle - The second stage reduces the particle size further resulting in a consistent and dust free chip This technology allows material to be cut consistently so that it can be easily reprocessed through the injection molding machine. Because the TWINcut provides such a clean cutting action and has no screen, there is less maintenance which translates into lower labor costs. The TWINcut is available in three sizes (Photo 1). Clean out, maintenance and inspection is one of the simplest in the industry due to the swinging side-plates which fold out exposing the whole cutting chamber (Photo 2). - TC 68: accomodates sprues and runners that measure up to 6" x 8", ideal for presses of 50 tons or less, produces a 4 x 5 mm particle size and can handle up to 12 pounds per hour - TC 1013: accommodates sprues and runners that measure up to 10" x 13”, is perfect for presses of 250 tons or less, produces a 6 x 6 mm particle size and can handle up to 35 pounds per hour - TC 1517: accommodates sprues and runners that measure up t 15" x 17”, is designed for presses of 500 tons or less, produces a 6 x 6 mm particle size and can handle up to 65 pounds per hour There are several specialized options available for the TWINcut such as: - A force fed control system within the hopper known as the Bridge-Buster helps to eliminate large runner bridging and downtime due to back-up and overflow, allows the operator to use larger runners for regrind, maintains a consistent blend of regrind and virgin material, and most importantly keeps your production running smoothly - Electrical auto-stop reverse, overload / stop / relay proximity switches, and strobe lights or horn - A Clean Room Design that provides a completely controlled processing environment allowing for full operation within the clean room The TWINcut will be a welcome addition to Motan’s current product line that features only the most innovative and efficient material handling equipment in the industry. For more information please contact Motan Inc.: Toll Free: 1-800-991-9921 (269) 685-1050 motanusa@motan-inc.com www.motan.com
