Ultramid® B3ZG7 OSI PA6 (Polyamide 6)- Ultramid OSI - 'Optimized for Stone' Impact for Automotive Oil Pans
With its strategic placement on the underside of the vehicle, automotive oil pans must withstand vibration, long-term heat aging in oil and be impact resistant to objects kicked up from the road.
With its strategic placement on the underside of the vehicle, automotive oil pans must withstand vibration, long-term heat aging in oil and be impact resistant to objects kicked up from the road. Based on these performance criteria, oil pans are currently made of cast aluminum, stamped steel or metal-plastic-metal. Now there is a new material option that provides weight reduction, part consolidation and feature integration that can be used for automotive oil pans - Ultramid® B3ZG7 OSI. more...
