UV2000 UV Condensation Weathering Device
The UV2000 is an affordable UV condensation weathering device with improved test result reproducibility and lower operating costs. · Intuitive touch screen and display · Irradiance control: four SmartLight monitors for controlling irradiance reside externally so irradiance control is not affected by chamber temperature · Irradiance calibration: the optional hand-held, wireless irradiance calibrator quickly connects to the UV2000 without opening the door or interrupting the test cycle · Temperature control: Atlas Black Panel temperature control provides precise temperature control throughout every test cycle · Condensation Cycle: Water vapor to create condensation is produced by a heating reservoir located in the bottom of the test chamber · Dual safety (hardware and software) for quick shut off of main control due to the door opening · Net weight: 129 kg · Gross weight: 222 kg · Exterior dimensions: 155 cm H x 135 cm H x 51 cm D
