Deflection Results (X, Y, Z, Total) - The deflections of the part relative to the reference plane defined when specifying the boundary conditions for the warpage analysisReference Plane – Defined by three constraint points, this is a plane relative to which the warpage deflections are measured.Material Orientation – The material orientation direction for each element.
Material Orientation – The material orientation direction for each element. Material orientation direction can affect the warpage of a part since shrinkage parallel and perpendicular to flow direction is different.
