YCI to Show a Variety of New YCM Machines at WESTEC Booth # 2928
YCI will showcase the New YCM XV1020A High Performance Vertical Machining Center with powerful MXP100i Control by FANUC.
YCI will showcase the New YCM XV1020A High Performance Vertical Machining Center with powerful MXP100i Control by FANUC. The New XV1020A is built with the state of the art technologies and packed with features at pricing you can afford. It includes a newly designed full enclosure, powerful 30 HP, 10,000rpm spindle with High/Low Shifting Isolated Direct Drive Spindle Motor and high efficient chip disposal system as standard. The travels are 40” X-axis by 20” Y-axis with fast 24 tools ATC 40 taper magazine. Also at the show will be the redesigned XV560A High Performance Vertical Machining Center with the MXP100i control by FANUC, 10,000rpm spindle, 40 taper, and 20 tool ATC. This machine has a small footprint with new full enclosure for shop looking for fast production and accuracy. The WV108A 40 taper Vertical Machining Center is designed structurally for heavy and robust machining requirements. This machine also has extra deep 30" Y-axis and 44" X-axis travels providing production flexibility in a machine with relative small footprint therefore more space to grow for your business. Last but not least, YCI will display two High Performance Turning Centers: The GT250B Boxway High Performance Lathe with powerful TXP100e Control by FANUC, 10” chuck and 10 tool turret that has 13.7" turning diameter with 20" turning length. The other is GT200MA with Turning and Milling capabilities paired with TXP200e Control by FANUC, 6” chuck, 6000 rpm spindle, and 12 station VDI Turret that has extra large 3-piece coupling for smooth clamping and milling performances.
