Energy-Saving Haitian IMMs
Screw and Barrel Wear
Screw and barrel wear is critical in all plasticating applications whether is it extrusion, injection molding, and blow molding, or twin screw extrusion.
Screw and barrel wear is critical in all plasticating applications whether is it extrusion, injection molding, and blow molding, plus twin screw extrusion.
Excessive screw and barrel wear can cause instable throughput or recovery on reciprocating screws, increased melt temperature and reduced plasticating rates.
Some of the causes of excessive wear are:
  • Screw straightness
  • Barrel straightness
  • Barrel alignment to the gearbox
  • Screw/barrel concentricity
  • Screw speed
  • Screw flight to barrel liner compatibility
  • Polymer being process
  • Fillers in the polymer
  • High headpressure
The accompanying chart shows the typical rebuilding requirement for various applications. Critical would be for a close tolerance produce and non-critical may be for a process such as making plastic lumber.
________________________________________________________________________________
Built for decades
Get Webinar & Slides
Blending & Dosing
Run Lights Out
Global Leader in Extrusion Tooling
gravimetric blending and dosing
Smartflow TracerVM Flow Meters for mold cooling
Good part
