Choosing The Correct Vacuum Receivers
Click image to enlarge
Standard Vacuum Receivers are mounted on top of all material destinations except process machines. Machine mount JIT models are mounted on process machines. A vacuum pump pulls a strong vacuum which cause material to be drawn from the source and deposited in the vacuum receiver.
Choosing the Correct Receiver
  • Receiver size is determined by the flow rate required and the type and bulk density of the material being transferred.
  • Machine Mount JIT models are used on process machines.
  • Powder Receivers are used for powder and dusty regrind.
  • Stainless steel is the most durable material for most applications
  • Abrasive materials require custom options be added to the receiver which may include:
    – Thick-wall wear plates
    – Electro-less nickel plating
    – Ceramic coatings
  • Tangential inlet with flapper and gasket minimizes material degradation and allows use with a common line and central material selection manifold system.
  • Neoprene seal on dump throat assures no loss of vacuum.
  • When powders (like PVC) are being conveyed, specify powder receivers, that Are designed with special filters and blowback, to avoid clogging and maintain energy efficiency.
  • No-tools access for cleanout is important.
  • Machine mount models are generally supplied with a height-adjustable photo eye level
  • sensor, base plate adapter, dump valve and quick disconnect clamps for easy clean out.
TIP - Larger receivers are better
   – Cycle fewer times and increase pump capacity
   – Reduce wear and tear on pumps and valves
Copyright © Gardner Business Media, Inc. 2012 All rights reserved.
