Pellet & Regrind Loaders
Click image to enlarge
Vacuum loaders transfer pellets and regrind from one or more sources (usually a Gaylord) to a single destination (usually a blender, drying hopper or machine throat).
Hopper mount models (typically have capacities that range from 1/8 through 1 cu. ft.)
Machine mount models typically range from 1/8 through 1 cu. ft.
Options for abrasive or hot materials ( over 250° F.) are available.
There are several variations on loader design:
  • Conventional dump throat
  • Flat bottom with internal dump throat
  • Internal filter screen to collect dust & fines
  • Filter-less design
  • Receivers may be stainless steel, carbon steel or aluminum
  • Exterior surface may be painted or brushed – even electro-polished
Some features to look for include:
  • Stainless steel body – wears longer
  • Modular design – for easy access and cleanout
  • Tangential Material Inlet Deflector/Flapper
Provides cyclonic air/material separation which minimizes material degradation
  • Deflector flapper w/ gasket – ensures that blowback does not travel down material line
  • Gasket on dump throat - maintains seal for high vacuum level
  • ‘No-load’ alarm and silencer button – warns of empty material source
  • Automatic pulsed blowback – to reduce frequency of manual cleaning
  • Machine mount models should have level sensor – to avoid over loading
Typical accessories include:
Typical Option:
  • Brushless motor – to reduce maintenance
DATASHEET: VACUUM LOADERS
