MVP Maxflo Vacuum Pump Series
The MVP (MaxFlo Vacuum Pump) series for high-vacuum polymer conveying applications generates higher vacuum levels at a modest price premium vs. traditional positive displacement pumps. Use of the high vacuum is an alternative to increasing line size, which reduces pressure drop but increases energy usage. The MVP conveys more material over longer distances, as compared to conventional pumps. The units are designed to eliminate plugged conveying lines, starved machines, and insufficient throughput capacity.
Use of the high-efficiency MVP pumps allows system expansion, increased throughput and conveying distance, conveying to multiple destinations with one pump, and decreased energy consumption. The heavy duty MVP series is rated for operation up to 16 inches of mercury (Hg). Exclusive spiral flow pump technology minimizes sound emission substantially versus traditional positive displacement pumps, so no noise reduction blankets are needed.
DATASHEET: MAXFLO VACUUM PUMP
