Matching A Control to Your System
Below are charts showing typical feature choices for Fixed I/O Controls and Expandable Controls. Simply click on the Maximum Number of receivers in your system (L.H. Column) and you will be linked to details about controls for that number of receivers.
| Fixed I/O Controls Features | |||||||||
| *Max# of Receivers | Max# of Pumps | **Proportioning | No-Load Alarm | Purge | Blowback | Ethernet Capability | Operator Interface | Power Voltage | I/O Voltage |
| 34 | 3 | ***Standard | Alarm/Light (Strobe Opt) |
10 | (16 or 32 Optional) | Optional | 5.7" Color Touch Screen |
115 VAC 230 Opt. |
24 VDC 115 Opt. |
10 | Optional | 4" Monochrome Touch Screen |
115 VAC 230 Opt. |
24 VDC 115 VAC. |
| 20 | 3 | ***Standard | Alarm/Light (Strobe Opt) |
8 | (16 Optional) | Optional | 5.7" Color Touch Screen |
115 VAC 230 Opt. |
24 VDC 115 VAC |
8 | (16 Optional) | Optional | 4" Monochrome Touch Screen |
115 VAC 230 Opt. |
24 VDC 115 VAC |
| 10 | 2 | ***Standard | Alarm/Light (Strobe Opt) |
6 | (10 Optional) | Optional | 5.7" Color Touch Screen |
115 VAC 230 Opt. |
24 VDC 115 VAC |
6 | (10 Optional) | Optional | 4" Monochrome Touch Screen |
115 VAC 230 Opt. |
24 VDC 115 VAC |
| 5 | 1 | ***Standard | Alarm/Light (Strobe Opt) |
N/A | (5 Optional) | Optional | 4" Monochrome Touch Screen |
115 VAC 230 Opt. |
24 VDC 115 VAC |
| 6 | 1 | Yes | (Horn/Light Opt) | N/A | N/A | N/A | Integrated LCD Screen |
115/230 | 24 VDC 115 Opt. |
| 5 | 1 | N/A | Horn Standard (Horn/Light Opt) |
N/A | Yes | N/A | Integrated LCD Screen |
| 1 | 1 | 1 Prop or 1Purge Valve |
1 Prop or 1 Purge Valve | Yes | N/A | Integrated LCD Screen |
115/230 | 26 VDC 115 Opt. |
| 1 | 1 | N/A | (Horn/Light Opt) | N/A | Yes | N/A | Integrated LCD Screen |
115/230 | 27 VDC 115 Opt. |
| Note: # of receivers dependent on pump capacity and parameters of system design ** Proportioning can be added to any receiver with a proportioning valve and a separate control. *** Separate proportional settings may be made for each optional proportioning receiver within each pump system, but all valves int aht system are connected with a common signal. In operation, all proportioning valves within that pump system operate at the same time. |
| Expandable Control Features | |||||||||||||
*Max# Receiv- ers |
Operator Interface | Receivers | Max# of Pumps |
Purge Valves/Blowback |
Proportion- ing |
No-Load Alarm |
*** AudioID Source |
*** Audio ID Destination |
Silo Monitor ing |
Ethernet Capability | Power Voltage | I/O Voltage | |
| 120 | 10" Color Touch Screen |
32 (Main HMI Panel) |
5 (Main HMI Panel) | 25 PurgeValves or Blowback (Main HMI Panel) |
**Standard | Horn/ Light |
Yes | 115 VAC |
24 VDC or 115 VAC. |
| 120 | 6" Color Touch Screen |
Yes | 115 VAC |
| 104 | 6" Color Touch Screen |
16 (Main HMI Panel) |
5 (Main HMI Panel) | 10 PurgeValves or Blowback (Main HMI Panel) |
Yes | 115 VAC |
| Options |
Up to 4 Optional |
Blowback Cards 16 BB/Card Up to 2 ea. (Factory Installed) |
Alarm/ Strobe Optional |
5-Port Optional For Remote HMI |
Optional 230 VAC |
Expan- sion Modules |
Up to 11 Modules 8 Receivers/ Module |
Up to 3 Modules 5 Pumps/ Module |
Up to 3 Modules 16 Valves/ Module |
Up to 16 Modules 16 Blowback/ Module |
Up to 4 Modules 16 Sources/ Module |
Up to 8 Modules 16 Destinations/ Module |
Up to 3 Modules 4 Silos/ Module |
| For Main Panel w/32 Stations Up-To Totals/Funcation Based on Number of Modules Added |
(32 Main Panel) Xpand to: 40,48,56,64, 72,80,88,96, 104,112,120 |
(5 Main panel) |
(25 Main panel) Expand to: 40,56,72 |
Opt. BB Cards 16 BB/card Up to 2 ea (Factory Installed) Expand to: 48,64,80,96,120 |
Expand to: 32,40,48,56, 64,72,80, 88,96,104, 112,120 |
Expand to: 16,32, 48,64 |
Expand to: 16,32,48, 64,80, 96,112,128 |
Expand to: 4-8-12 |
| For Main Panel w/16 Stations Up-To Totals/Funcation Based on Number of Modules Added |
(16 Main Panel) Expand to: 24,32,40,48, 56,64,72,80, 88,96,104 |
(5 Main panel) Expand to: 10,15,20 |
(10 Main panel) Expand to: 25,40,56,64 |
Opt. BB Cards 16 BB/card Up to 1 ea for FXS-516 (Factory Installed) Expand to: 32,48,64, 80,96,104 |
Expand to: 16,24,32, 40,48,56,64, 72-80,88, 96,104 |
Expand to: 16-32- 48-64 |
Expand to: 16,32,48, 64,80,96, 112,128 |
Expand to: 4-8-12 |
Max Total/ Function |
104-120 Receivers |
20 Pumps |
64 Purge Valves | 104-120 Blowback |
104-120 Prop. Valves |
64 Sources |
128 Destinations |
12 Silos | |||||
| * Number of receivers dependent on pump capacity and system design. ** Separate proportional settings may be made for each optional proportioning receiver within each pump system, but all valves in that system are connected with a common signal. In operation, all proportioning valves within that pump system operate at the same time. Discreet proportioning is included for receivers wired to modules. ***Auto ID allows inputting of desired material source and destination information into the control, and the correct connection must be confirmed by the (optional) proofing connections at the manifold, or an alarm signal is generated and loading is not permitted. | |||||||||||||
