rotational molding single & multi layer parts CFAs
3 Ways Outgassing Problems Impact the Injection Molding Cycle
Sponsored Content
Gas and air entrapment can cause a variety of problems in injection molding, including part burns, short shots, voids and blemishes, even clogged vents. Here’s how that can impact the molding cycle.
Proper venting is essential to molding a defect-free part. Without it, air and gas are trapped in the mold, compressing and heating as the cavity fills. Ultimately, this can negatively impact the injection molding cycle in three major ways: higher risk of part defects; higher cleaning and maintenance costs; and longer cycle times.
  1. Part Defects
Trapped gas is one of the most common causes of part burns and can also lead to short shots and voids; blemishes; and discernible knit lines that weaken the part.
  1. Cleaning/Maintenance Costs
Trapped gas can cause residue buildup in vented pins, which then necessitates frequent production interruptions to clean the tool. It can even cause corrosion of the tool steel, thereby increasing tool maintenance costs.
  1. Longer Cycle Times
The most common response to the problem is to slow down…READ MORE.
Injection molding machines
NEW CM-17d Spectrophotometer
Blending & Dosing
Plastics Recycling Latam STD
Process Cooling
Plastics Size Reduction
2025 Twin Screw Report
PT Top Shops
Process Cooling
Blending & Dosing
PT Top Shops
Dust-Tight Bulk Bag Unloaders
