Preventative Maintenance Cleaning System
In this Digital Demo, iD Additives reviews the functionality of its iD Eco-Pro 360 cart.
iD Additives’ iD Eco-Pro 360 cart is a Preventative Maintenance Cleaning System with a pump and filter combination unit. It removes, protects and helps prevent rust within the cooling passages, heat exchangers and water lines. The built-in filter function allows the Eco-Pro 360 solution to remain at peak performance for optimal reusability.
Eco-Pro 360 is a non-hazardous, water-based chemical that removes rust and mineral scale buildup. It is used with the Eco-Pro Cart to flush out, clean and restore cooling passages. The cart runs off of compressed air, so there’s no need to run an electric cord to it. A key highlight for Eco-Pro 360 is that it is reusable due to the built-in Eco-Pro cart filter.
For users with closed-loop systems such as extruders and thermoformers, the next step is to prevent the cause of these negative side effects. Once systems are restored, they can replace their water with Cool-EX, an all-organic, high-performance coolant that inhibits corrosion, mineral scale and fouling.
Plastics Recycling Latam
Go Beyond Blending
Shell Polymers (Real)ationships start here ad.
