Innovative Feeders, powered by Orbetron LLC
Largix printer platform
Largix’s Production Solution large-format 3D printer makes it possible to print with PP and PE materials with minimal shrinkage, by softening the exterior — but not melting — the filament. Screenshot: Largix from video
When Ronen Orr and Amir Sheelo began the collaboration that would become Largix in 2014, they knew they wanted to develop a solution for reducing manual production of industrial goods using additive manufacturing (AM) as an alternative. They had seen the challenges facing industries that have historically relied on skilled labor, and saw AM as an automated way to reduce that labor and improve quality and throughput. They also knew that pursuing additive for industrial parts would mean rejecting most of the 3D printing technologies and materials then available, and plotting a new course toward durable, high-quality components.
“We did not start by developing a technology and looking for a market,” Sheelo says. “In commercial products, it’s all about quality standards and materials. That’s where we started.”
The Israel-based startup is in the process of launching a new polymer 3D printing technology targeted for the production of industrial products, specifically heavy-duty products made of polypropylene and polyethylene (PP and PE). These materials account for 50 to 60% of global polymer consumption, Sheelo says, but they have historically been difficult to 3D print. The plastics can expand up to 30% in a molten state and will retract an equal amount when cooled and solidified; this dynamic behavior makes it difficult to avoid warpage and maintain dimensions in a 3D printing process that relies on melting such as fused filament fabrication (FFF).
3D Printing with Square Filament
To avoid these challenges, Largix has developed a 3D printing process that mostly keeps the polymer in its solid state. Instead of melting and extruding the filament, the printer uses a laser beam to melt just the outer “skin” of each strand so that it can attach to previous and adjacent layers. Up to four filaments can feed through the printhead at once, all of them laser-softened in unison, allowing for rapid material buildup. The company produces the feedstock itself, which has a square profile to maximize the surface area for bonding. The technique creates a monolithic part with Z-axis strength above 90%, Sheelo says.
(And that monolithic part can contain multiple materials, he notes. While up to four filaments can be feed through the printhead at once, there is no need for all of them to be identical. It could be possible, for instance, to build a wall that has colored polypropylene for aesthetics only on one (external) side, then a glass fiber-reinforced filament for strength, then a recycled PP filament, and a fourth filament with some other enhancement like a UV stabilizer additive. As long as the base material is the same, the filaments will weld and function together similar to plain PP.)
Cold 3D Printing and Hybrid Manufacturing
This “cold” 3D printing process is offered on the company’s Production Solution machine. The gantry-based printer is totally modular and offers a large build volume; the machine running at Largix’s headquarters has a build volume of 4 by 3 by 3 meters (limited vertically only by the facility’s ceiling height) but can be customized to the needs of the user. The automated platform can be equipped with multiple printheads as well as a robotic arm for CNC milling, making it a hybrid manufacturing system.
Because the material remains relatively cool and solid throughout printing, machining can be done in sequence, without the need to wait for the printed material to cool or contract first. With just a few hours of setup, one Production Solution can run for several days largely unattended, as long as it is kept stocked with material. The company projects that each Production Solution could consume between 120 and 150 tons of material per year.
“This is autonomous, nonstop production,” Sheelo says. The machine reduces both the need for skilled workforce and the amount of manual labor required to produce industrial parts. And the company already has an initial industrial niche in mind: custom chemical storage tanks.
Digital Production of Chemical Storage Tanks
When mass produced, these tanks are made through rotational molding with reusable tooling. But custom chemical tanks require a far more manual process, which today is performed by many discrete companies in various regions of the world. Largix believes its manufacturing system and materials offer a digital alternative to fabricating these tanks by hand, along with the ability to create variable wall thickness and other geometries that would be difficult or impossible to produce manually.
rendering of a chemical storage tanks
Large, custom chemical storage tanks like this one could be made faster and through a more automated process with the Largix 3D printer. Screenshot: Largix from video
Its first beta tester, a tank manufacturer in Israel, currently fabricates custom tanks in 50 to 60 hours through manual means. With the Production Solution set to arrive in spring of 2023, this company expects to be able to produce each custom tank in just 2 to 3 hours on this platform.
Chemical tanks won’t be the only application for Largix, of course. The company is already working on applying its technology to produce custom concrete molds, another industrial product today largely built by hand. Parts for aviation, automotive, construction, architecture and other industries will follow.
HAIDLMAIR NPE2024
Plastics Recycling Latam
Dover Clear
Dri-Air
Go Beyond Blending
KraussMaffei Launches Two Additive Manufacturing Lines at K 2022
Long established in injection molding, extrusion and polyurethane reaction process machinery, 184-yr-old KraussMaffei prepares to enter the industrial additive manufacturing market.
3D Printing of Injection Molds Flows in a New Direction
Hybrids of additive manufacturing and CNC machining can shorten tooling turnaround times.
Custom Molder Manages Growth on Several Fronts
Adding people, plants and machines, expanding capabilities in LSR, high-tonnage presses, automation and 3D printing—EVCO Plastics maintains momentum through challenging times.
How Additive Manufacturing Can Help, not Hinder, Injection Moldability of New Designs
Four cost drivers—design for moldability, mold-base size, internal componentry, polish/custom finishing—dictate the financial and processing success of a molded part design. Learn how 3D printing can assist this process, while also understanding its potential pitfalls.
Using Large-Format Additive Manufacturing for Serial Production
First tools, then production parts. This pattern with industrial 3D printing at small and mid sizes has now come to the biggest additive machines as well.
Custom Canine Wheelchair From Carbon Fiber-Reinforced PP: The Cool Parts Show #44
A dog with a condition that affects her mobility gets a custom 3D printed wheelchair in this episode of The Cool Parts Show, enabled in part by a new polypropylene filament.
How a Solid-State Process Stood Firm Until Additive’s Moment
Early on, this company saw the promise of friction stir welding for building forms in layers. Few understood at the time. They understand now, in part because this process offers benefits such as blended materials and freedom from stress that other metal AM approaches can’t match.
Shuttle Mold System
