Dosing Done Right
High-Output Thermoformer for APET Food Packaging
WEB EXCLUSIVE: The GN DX series of contact-heat, cut-in-place thermoformers from GN Thermoforming Equipment, Chester, Nova Scotia, is a new line of servo-driven machines that provide significantly greater cutting capacity for making APET food packaging.
WEB EXCLUSIVE:
The GN DX series of contact-heat, cut-in-place thermoformers from GN Thermoforming Equipment, Chester, Nova Scotia, is a new line of servo-driven machines that provide significantly greater cutting capacity for making APET food packaging. The GN 3021 DX has 30 x 21 in. forming area and the GN 3625 DX a 36 x 25 in. area.      Reinforced cast beams provide increased rigidity for cutting APET. These machines handle 50% more linear knife length than standard GN machines. The GN 3021 DX operates at 25 to 30 dry cycles/min. Power consumption is 7.5 kwh/hr. At 12 ft long and 6 ft wide, the machine is said to be compact for its platen size.      The GN 3625 DX offers throughput up to 30 cycles/min with power consumption of only 12 kwh/hr. Both machines can run sheet from 0.15 to 1 mm thick.      The transport system and common-edged cutting dies together help reduce overall scrap to 12% to 14%, well below the industry standard, according to the company. The machines come with multi-zone contact heating, electric preheater, static eliminator, built-in powered unwind, adjustable part stripping for increased speed, and remote diagnostic capability. (902) 275-3571 * gnthermoforming.com
Improved Stainless 420 ESR
pipe and profile extrusion chemical foaming agents
Dover Clear
Insert molding automation
Plastics Recycling Latam
extrusion lines for encapsulant film for solar
Registration is on Us
Cranes, Conveyors, Racks, Loaders, Accessories
