Make Your Machine Time Count
At the end of the day, injection molders are ultimately only selling one thing: machine time.
Getting and keeping injection molding machines running, despite all the other services processors typically offer, often means the difference between boom or bust for molders. With that in mind, Plastics Technology has created an entire session at its Molding 2016 Conference & Exhibits (Westin New Orleans; March 29-31) devoted to ‘Establishing & Maintaining a Robust Process’.
Eight speakers from leading custom molders, machinery suppliers, OEMs, consultancies and plasticating component manufacturers will address how to create, maintain and repeat a robust molding process, replacing downtime and scrap with on-time deliveries and profits.
Joachim Kragl, director Advanced Injection Molding Systems & Processing at Engel, will walk attendees through the latest developments for the company’s iQ control package, including the most recent advances which allow the system to automatically adjust clamp pressure to compensate for viscosity changes in the material and create for consistent parts without tinkering with back pressure.
Robert Gattshall (author of this Plastics Technology article on scientific molding) will present on process development and establishing effective process limits, including defect and variation thresholds, while asking which process outputs should be monitored. In addition, Gattshall will speak to a problem shops with a mixed machine stable face: the lack of standards across machine manufacturers and machine-to-machine variation.
As important as melt temperature is to the molding process, its true measurement has remained illusive if not completely indiscernible. Two papers at Molding 2016 will directly address the “mystery of melt temperature.” Michael F. Durina, inventor and president Md Plastics Inc., will talk about the development of an inductive electromagnetic melt temperature sensor that is actually located with the machine barrel and nozzle. This new technology relays data on melt temperature, viscosity and equipment condition in real time.
In addition to Durina, Mark Berry of PPD Tech LLC and Yasuo Ishiwata, of Futaba Corp. of America will discuss use of a fiber-optic infrared sensor to measure true melt temperature. In addition, the paper will discuss how the technology can help find the ideal cooling time by measuring key parameters while the part is in the cavity.
Tessy Plastics Virginia, whose innovative integration of process and production monitoring for a paperless plant was highlighted in this Plastics Technology article, will also present at Molding. Doug Jobe, Tessy’s director of operations, will discuss how his company’s real-time process monitoring is helping it grow into Industry 4.0.
Scott Rogers, technical director of Noble Plastics, will present a paper entitled “The Value of Predictive Inspection.” Specifically, Rogers will share a method whereby dimensional inspection of molded parts can be predicted and how this method can be used to enhance mold design, part design, and production capability.
Suhas Kulkarni, author of this two-part series on how to optimize pack and hold times for hot-runner and valve-gated molds, will conclude the session with a discussion of Design of Experiments as a means to process simulation. Founder of consulting and training firm FIMMTECH and author of Robust Process Development and Scientific Molding, Kulkarni will discuss how out-of-spec parts can lead molders to change one parameter, without accounting for how that alteration can have knock-on effects with other specifications. His solution: A Design of Experiments simulation that’s done after actual data are collected and analyzed from a set of molder-led experiments. “Simulation is now based on actual data and not on initial flow simulations typically done at the part and mold design stage,” Kulkarni notes.
Register now and save for Molding 2016! Make the machine time you sell count.
Video: Ultradent Bags Both Hot Shots Prizes at PTXPO 2023
Topping five other entries in voting by fellow molders, the Ultradent team talks about their Hot Shots sweep.
Read MoreMolder Opts for Machine Flexibility for Complex Jobs
AE Plast opted for tiebarless multimaterial Engel victory machines as it took on complex parts for the appliance and power tool market, including a 3K housing for Dremel’s rotary tool.
Read MoreNew Multicomponent Injection Molding Machine Line Launches
FCS Group’s X-Type parallel quartet injection molding machine features four injection units aligned in parallel for a smaller footprint.
Read MoreZAG Equipment Sales Partners with Portugal’s Plasdan of Portugal
Under the agreement, ZAG will sell and service Plasdan’s add-on injection units and fully electric rotary tables for multicomponent injection molding.
