New Tinius Olsen VectorExtensometer U70 testing
Stainless Steel Hydrotherm Water System
Re-engineered to improve accuracy, reliablity of operation and increase output, the Hydrotherm has the highest quality components and construction materials in the industry.
Re-engineered to improve accuracy, reliablity of operation and increase output, the Hydrotherm has the highest quality components and construction materials in the industry. The Hydrotherm surpasses all competitive systems by providing stainless steel as the main component for wetted surfaces. Where many of our competitors supply carbon steel and cast iron systems, only Mokon provides the Hydrotherm with stainless steel components including a stainless steel pump, heater canister and pump suction manifold. The Hydrotherm is available with heating capacities up to 24 kW, pumping capacities up to 3 hp, and flow rates of 15 gpm to 60 gpm. Maximum operating temperature is 250 degrees F (121 degrees C).
Make Every Pellet Count
AM Workshop
Go Beyond Blending
Plastics Recycling Latam
Orbetron new for 2024 micro twin screw feeder
Dover Clear
Bole Machinery
Registration is on Us
Mold Cooling Visibility with TracerVM Flow Meters
