SPONSORED
Drying
Dryers are used to minimize or eliminate problems that moisture in the plastics cause during processing. Includes resin drying; hygroscopic resins; desiccant dryer; wheel dryer; vacuum dryer; drying PET; drying PC; drying ABS; drying nylon.
ESSENTIAL READING
VIEW ALLHow To Prepare Your Dehumidifying Dryers for Summer
Seasonal humidity changes can impact the performance of your dehumidifying dryer. Take these steps to help prevent costly failures.
Read MoreBozzelli’s Guide To Specifying a Dryer
Read MoreFollow These Seven Management Tips for More Consistent Resin Drying
Equipment and advice sure help, but ultimately, good management makes the difference.
Read MoreSpring Tips for Dryer Maintenance
The warm, humid weather really puts a strain on both the regeneration and process, so it is important that everything is in perfect working order. The time to check is now.
Read MoreWhat You Need to Know About Drying Specialty Nylons
PPA is being used more frequently by molders for demanding high-heat applications in automotive and other markets. While in the nylon family, it does not dry quite like nylon. Follow these tips.
Read MoreLatest Drying News And Updates
Advanced Blending Solutions Fully Integrates Thoreson McCosh Brand
Move aimed at positioning ABS as complete solutions provider of auxiliary equipment.
Read MoreWittmann Debuts Energy-Efficient 'Basic' Dryer
Dual-cartridge technology is designed to offer high energy efficiency and ease of maintenance in a compact design.
Read MoreMaguire System Unifies Blending, Feeding, Conveying and Extrusion Control
Control of gravimetric blenders, feeders, conveying and even extrusion in a single, streamlined system.
Read MorePiovan Launches ‘Breakthrough’ Dryer for PET, rPET
Faster drying cycles, quicker changeovers thanks to three-stage temperature progression and unique air-management technology.
Read MoreNext-Generation Drying, Blending, Feeding from Maguire
Vacuum dryer billed as more affordable and energy efficient than ever.
Read Moremotan 'Swift' Series of Auxiliaries Designed to Maximize Efficiency
Series covers the entirety of motan’s product line.
Read MoreFeatured Posts
ICYMI: September Roundup
The FYI on MDO, turbulence as a good thing and gearing up for a new future at Winzeler Gear all feature in the top articles from September that you might have missed.
Read MoreRunning PET Flake? Here's How a Crystallizer Can Help
Crystallizers were designed and manufactured by many auxiliary equipment manufacturers in the 1970s with the mistaken belief that packaging-grade virgin PET would eventually become available to processors in amorphous, rather than crystalline pellet form.
Read MoreOvercoming Drying Hopper Ambient Air Leaks
Consider using a compressed-air-operated discharge valve. This provides a positive seal when it closes and ensures that no wet ambient air seeps into the drying hopper.
Read MorePTXPO Recap: Smarter Resin Drying & Conveying Automation
Check out what you missed on the PTXPO show floor. In this video, Editorial Director Jim Callari breaks down how AI is changing the game in plastics manufacturing.
Watch'Smart,' Moisture-Based Drying Technology Enhanced
At NPE2024, Novatec relaunches DryerGenie with a goal to putting an end to drying based on time.
Read MoreBlending Specialists ABS Relaunching Thoreson McCosh Dryer Line
NPE2024: Advanced Blending is taking the wraps off reinvigorated Thoreson McCosh drying line.
Read MoreFAQ: Drying
How to dry resins?
Proper drying requires attention to detail in the following areas: temperature and moisture content (dew point) of the inlet air, volumetric flow rate of the air across the pellets, time the material is in the drying hopper, and temperature of the return air coming back from the hopper to the drying unit. There are other areas of concern related to the design and maintenance of the system. This also assumes that a desiccant dryer is being used.
How can I achieve more consistent resin drying?
Control Initial Moisture Levels in Undried Resin
Size Dryers Properly
Dry at Correct Temperature
Keep Drying Hoppers Full
Limit Machine-Side Material Inventory
Keep Airflow Clean and Consistent
Invest in a Moisture Analyzer
Drying Supplier Categories
- Water, Oil Manifolds & Couplings
- Water Treatment/Filtration Systems
- Heat-Transfer Fluids
- Heat Exchangers
- Chillers
- Hot-Water or Oil-circulating Temperature Controllers
- Heat Pipes & Related Thermal Conductors
- Cooling Towers
- Heaters, Heating Elements
- Used Machinery
- Heat-Recovery Equipment & Systems
- Equipment Cleaning Services
- Ovens, General
