Xaloy Xalence AI
In one sense, the addition of 3D printing to KraussMaffei’s technology portfolio is a natural extension of the company’s specialty in plastics processing equipment. Its large-format additive manufacturing (LFAM) PowerPrint Flex robot-based extrusion 3D printer and PowerPrint Plus gantry-style system complement existing product lines for injection molding, extrusion and reactionary processing. Additive manufacturing is now one of multiple equipment types available to customers for making polymer-based parts.
Dan Rozelman, KraussMaffei
Dan Rozelman is technology and application sales manager at KraussMaffei in Brighton, Michigan. This temporary divider produced on one of the company’s LFAM 3D printers is just one of many internal uses it has found for the technology it now manufactures and supplies. Source: Additive Manufacturing Media (All Images)
However, there’s another factor at work behind KraussMaffei’s 6+ years in developing its 3D printing technology: significant internal applications.
“We would have a use case for this technology even if we weren’t selling the machines,” says Dan Rozelman, technical and application sales manager.
At KraussMaffei’s production facility in Brighton, Michigan, this point is evident. The building functions as a factory for machine assembly, a showroom of technology, a test bed for new customer machines before they are shipped out — and also, a manufacturing facility for tooling.
Large prototype or end-use molds, trimming fixtures, router tools, risers and other tool components are now 3D printed using KraussMaffei’s own additive technology, providing myriad benefits to both the manufacturer and its customers, the ultimate users of these tools.
KraussMaffei offers various machines that can fold, score, trim and stitch material, in addition to its foam-in-place, extrusion and reactionary processing equipment. 3D printing is now another product line, but also a new internal capability.
Plastics Processing, Reconfigured
KraussMaffei extruder
Both 3D printers use the same single-screw extruder, capable of depositing up to 70 kg of material per hour.
Founded in Germany in 1838, KraussMaffei has a long history in manufacturing technology and is well-known in the plastics processing industry. Its Michigan location supports the sale of equipment and tooling for foam-in-place, laminating, edge folding, trimming and scoring processes, all common in development and production of automotive interiors. But the company’s broad expertise in plastic forming and processing worldwide made it relatively easy to step into additive manufacturing.
“We know how to melt and control plastic,” Rozelman says. “We have the controls, the heating, the automation, the extruders. At a basic level, we rearranged those components to make our 3D printers.”
Stephanie Hendrixson, Chad Randolph and Dan Rozelman at KraussMaffei
Rozelman and Chad Randolph (project manager, center) walk me through the features of the PowerPrint Plus, the company’s gantry-style printer. While this machine has a more limited build volume than the robot-based PowerPrint Flex, its enclosure makes it possible to control ambient temperature for better results in certain materials.
Indeed, the company’s pellet-fed 3D printers work much like a more conventional extrusion line. The gantry-style PowerPrint Plus even uses the same linear drives found in its injection molding machines. But there are some differences in the equipment, like additional heat zones for the 3D printing extruder that wouldn’t be necessary for other processes.
The way that the company interacts with material suppliers has changed as well for additive manufacturing, with more frequent collaboration with pellet manufacturers to develop AM-specific formulations and qualify their materials for the process.
The two 3D printing products are similar in that they offer nozzles ranging from 2 to 20 mm; can deposit several grams per second up to 75 kilograms of material an hour out of a single exruder; and have the capability to run lights-out with cameras and the company’s Data Explorer tool capturing data along the way. Both machines print onto reusable build plates on a 16-zone vacuum table which can be heated up to 60°C.
interior of PowerPrint
Both the PowerPrint Plus (pictured) and PowerPrint Flex use a 16-zone heated bed with removable build plates. The plates are reusable and secured to the table with vacuum.
The primary differences are work envelope size and shape, as well as print environment. The enclosed PowerPrint Plus gantry machine has a 2 by 2.5 by 2-meter build envelope, with a chamber that can be heated to 180°C. The PowerPrint Flex, built on a Comau robot, prints in an open environment which enables multiplanar printing and a larger potential build volume.
Applications for LFAM
The Michigan facility offers print-on-demand and manufacturing services in other processes for customers up to a point, but the company does not wish to be a service bureau. The production that happens in Brighton is primarily prototypes and “pre-run” parts, to help customers assess equipment before a purchase or to “get them over the hump” with bridge production of parts while equipment is being installed.
While 3D printing of these early production run parts isn’t common, KraussMaffei is increasingly applying its LFAM technology to produce prototypes before tooling is created, enabling customers to be absolutely sure of the design before embarking on the expensive step of tool production.
In addition to selling machines, KraussMaffei also assists customers with development and production of the tooling — and this is where it has found the most critical use cases for LFAM.
Tooling for the processes that KraussMaffei customers most commonly require is typically machined from metal, often from large castings. Tooling or its components are often sourced from overseas, adding lead time to an already lengthy and expensive process.
An example of a 3D printed trimming tool (in orange) that could be used within a KraussMaffei machine to hold a formed automotive part for this process. Seen at Formnext 2024.
Offering polymer LFAM as an alternative to metal tooling has enabled the company to dramatically reduce lead times, which often gives the additive tool an edge. For scoring and router fixtures, for example, the company has realized significant time savings with 3D printing versus machining that make this solution compelling. Often, the 3D printed solution offers cost savings as well.
An Alternative to Casting for Risers
3d printed riser and conventional metal riser
This foam-in-place tool has both conventional and 3D printed risers. The metal riser on top is machined aluminum, produced from a casting, while the bottom orange riser is 3D printed glass-filled PETG.
But there are many other benefits to be realized through 3D printed tooling, too. One killer application that the company has found is a common component of large tools called the riser. The riser does not form geometry directly, but holds the mold and supports instrumentation required in its operation. Risers are typically cast and machined aluminum, but at KraussMaffei they are now commonly being 3D printed from polymer composite.
The application arose first out of necessity. A customer had a tool that was being made in China that was held up in shipping; in order to develop the rest of the system around that tool, KraussMaffei 3D printed a riser primarily as a prototype. The company has since found that 3D printed risers printed from carbon fiber-filled polycarbonate (PC) or glass-filled PETG perform as well as, and actually better, than aluminum tooling.
The risers seen in the foam-in-place tool below are an example — one for each half of the mold. Each riser was 3D printed in about 8 hours using carbon fiber-reinforced polycarbonate, and then finish machined.
This tool features two 3D printed risers, this time produced from carbon fiber-reinforced polycarbonate.
“The time to machine these risers is about the same as it would be to machine an aluminum casting,” Rozelman says, “but the material cost is about 30% less, and there is a 40% weight savings over the aluminum tooling.”
Overall production time is about 1 week for a 3D printed riser, versus 10 weeks for a machined casting. The speed comes from the change in process as well as where the riser is produced.
“This is vertical integration of a process we wouldn’t typically do,” says Chad Randolph, project manager, referring to riser production.
“What we used to buy, we now make,” Rozelman adds.
Improved Tool Performance, Sustainability
But the greatest benefit of the 3D printed risers might be in their impact on tool operation. Aluminum conducts and dissipates heat well, which is sometimes desirable — but for a foam-in-place tool that must be kept within an ideal temperature range during operation, this is a challenge. Heaters must run constantly to maintain the temperature in the tool even as the aluminum structure works to remove it.
Polymer composite, however, is an insulator. KraussMaffei has found that in use, tools with 3D printed polymer composite risers keep more of the heat in the tool, preserving its temperature while also protecting the press from excess heat.
A riser for a tool in progress. The 3D printed risers still require machining like the cast counterparts, but start with less material, and are lower in weight and more readily recyclable for a more sustainable tooling option.
In addition, the risers’ lighter weight reduces stress on the machine motor and brakes. KraussMaffei estimates energy savings up to one-third over the tool’s lifetime, likely 5 years in production and 5 years in service, or more.
“The energy savings alone makes this a better solution,” Rozelman says.
Such tools mainly see compressive forces (typically 20 to 30 tons of downward force in use). Printed risers offer a compressive strength between 9,000 and 12,000 PSI, which is more than enough to support this tonnage. In addition, the lighter weight of the polymer riser makes it possible to support the tool over a larger area, which reduces flexural stresses on the tool.
There is another benefit to 3D printed tool risers that KraussMaffei sees over the long term: material sustainability.
“Today the price of billet aluminum is $2 to $7 a pound, depending on grade. We cost it out at $5 a pound,” Randolph says. But a significant amount of the aluminum purchased for a riser is never used, and loses its value. “Scrap price for aluminum chips is just under $1 a pound,” he says.
LFAM enables KraussMaffei to use less material from the get-go, saving material cost, and produce less waste. Additionally, the material is directly recyclable; according to the company, it’s possible to grind up old or unneeded fixtures and throw the flake right back into the printer, creating a circular economy for LFAM polymer composite parts.
Our Team Makes Every Pellet Count
outdoor central chillers
Accuracy you can count on
Process Cooling
Advanced Melt Flow
Plastics Size Reduction
PT Top Shops
The Connector Conundrum: 3D Printed Mold Tooling’s Role in Innovation
ReelView Fishing faced an electronics obstacle in the development of its new technology for underwater video. Additive manufacturing for moldmaking allowed for the speed necessary to iterate to a solution. How inventors and invention will benefit from new ways of obtaining production-ready tooling.
Xenia 3DF Materials for FFF Printing
Xenia filament materials for fused filament fabrication.
420 Stainless Steel Now Qualified With TrueShape 3D Printing Technology
NPE2024: Mantle's additive manufacturing technology is designed for precision tooling.
Smooth Operators: Vibration Compensation Improves Robot Performance
Ulendo is working to apply its vibration compensation algorithm to robots. This application is more complex than its initial market of fused filament fabrication 3D printers, but could result in faster, cheaper robots.
Robot Vs. Gantry for Large-Format Additive Manufacturing (Includes Video)
Additive Engineering Solutions, specialist at 3D printing very large parts and tools on gantry machines, now also uses a robot for large-format AM. Here is how the robot compares.
Automotive
3 Ways 3D Printed Tooling Is Speeding Automotive Prototyping
Catalysis Additive Tooling is using specialized 3D printed tooling for foam molding, compression tooling and sheet metal forming, offering automakers and their suppliers a faster, affordable route to functional prototypes.
KraussMaffei Extends Focus to Large-Scale, Sustainable Additive Manufacturing
Company adds large-scale, sustainable additive manufacturing to its portfolio of sustainable solutions for the plastics industry.
Xaloy Xalence AI
