New Tinius Olsen VectorExtensometer U70 testing
SIMCO Industrial Static Control's Conveyostat Static Neutralizers Help Maintain Plant Operations without Costly Interrup
Hatfield, Pennsylvania - SIMCO Industrial Static Control’s Conveyostat Static Neutralizers are designed to improve operations by preventing jams, plugs, nesting of materials, de-mixing and other problems resulting from static charge buildup in conveying systems.Equipped with static neutralizing bars, Conveyostat units neutralize the static charge buildup on conveyed material, cyclones and containers so that plant/equipment operations can be maintained without costly interruptions.
Hatfield, Pennsylvania - SIMCO Industrial Static Control’s Conveyostat Static Neutralizers are designed to improve operations by preventing jams, plugs, nesting of materials, de-mixing and other problems resulting from static charge buildup in conveying systems.Equipped with static neutralizing bars, Conveyostat units neutralize the static charge buildup on conveyed material, cyclones and containers so that plant/equipment operations can be maintained without costly interruptions. Once properly applied to the end of a conveying system, Conveyostat units can help to lower operating costs, reduce waste, improve product quality and material flow, and reduce machine downtime.SIMCO Industrial Static Control offers a variety of standard neutralizers ranging in length (9”-24”) and diameter (2” -12”) and can also design and build custom engineered systems for specialized filling requirements and large conveying systems. For all your static control needs, SIMCO Industrial Static Control, ISO 9001 certified, is unsurpassed in customer service, application analysis and product excellence. SIMCO Industrial Static Control, the worldwide leader in static control, has been providing static control solutions since 1936.
quick mold change solutions injection molders
Bole Machinery
Vacuum Tech for Plastics Manufacturers
LKIMM
Blending Revolution
extrusion lines for encapsulant film for solar
Improved Stainless 420 ESR
Vacuum Tech Guide for Plastics Processing
