Global Leader in Extrusion Tooling
Overcoming Drying Hopper Ambient Air Leaks
Consider using a compressed-air-operated discharge valve. This provides a positive seal when it closes and ensures that no wet ambient air seeps into the drying hopper.
Pete Stoughton, Polymer Drying Services
Vacuum loaders used to load materials into a drying hopper typically employ what is called a gravity-discharge valve. The discharge valve employs a flapper that hangs freely beneath the vacuum loader. When the material level within the drying hopper falls below the vacuum loader’s discharge valve flapper, it allows a path for ambient air to enter the top of the drying hopper due to the suction of the return air circuit (Figure 1).
FIG 1 — With a gravity discharge valve, when the material level within the drying hopper falls below the vacuum loader’s discharge valve flapper, it enables a path for ambient air to enter the top of the drying hopper due to the suction of the return air circuit.
Also, at this point the level switch built into the discharge valve closes and calls for more material to be loaded into the drying hopper. Next, a vacuum is applied to the loader body which pulls the gravity discharge valve into the closed position. (Figure 2) The vacuum loader will pull material from the source of supply on a timed cycle, which is manually adjusted for the optimum amount of time determined by the machine operator.
FIG 2 — When the level switch built into discharge valve closes, a vacuum is applied to the loader body which pulls the gravity discharge valve into the closed position.
When the vacuum loader’s timer completes its cycle and the vacuum is shut off, gravity takes over to allow the material within the loader body to force the flapper discharge valve to open and discharge the material into the drying hopper. (Figure 3).
FIG 3 — When the vacuum is shut off, the force of gravity enables material within the loader body to force the flapper discharge valve to open and discharge the material into the drying hopper.
During the time shown in Figures 1 and 3, the suction of the dryer’s return air circuit will be drawing some ambient air along with ambient moisture into the “closed loop circuit” via the dryer’s return air circuit.
In many cases, this small amount of ambient air entering the “closed loop air circuit” will not cause a problem due to several reasons such as:
  1. Dehumidifying polymer dryers are sized to perform well during the hot, humid summer months of June through September, when ambient dew point levels often reach as high as 60° to 80° F, and coast along with little effort during the relatively cool dry months from October through May.
  1. Some polymers such as ABS, acrylics and some others are mildly hygroscopic and easily dried.
  1. Some polymers such as DuPont’s Zytel (nylon) are more forgiving of moisture content and can be successfully molded with a moisture content of up to 0.20% or 2,000 ppm, according to DuPont’s Zytel molding guide.
However, some polymers are much more sensitive to moisture during processing. Polymers such as PET, PBT and most other polyesters (along with polycarbonate and some polyurethanes) can cause endless problems if not dried to extremely low residual moisture levels during the hot, humid summer months.
So how do we contend with a low volume of wet ambient air leaking into our drying system when processing extremely sensitive polymers during the hot, humid summer months?
The answer may be a compressed-air-operated discharge valve that provides a positive seal when it closes and ensures that no wet ambient air seeps into the drying hopper (Figure 4, right).
Another option is a custom-made transition hopper between the drying hopper and the vacuum loader, which will be filled with material and thereby block the path of ambient air entering the drying hopper through the vacuum loader (Figure 4, left).
FIG 4 — A compressed air-operated discharge valve provides a positive seal when it closes and ensures that no wet ambient air seeps into the drying hopper (top).
ABOUT THE AUTHOR: Pete Stoughton has more than 40 years’ experience with dehumidifying dryers and PET crystallizing systems. He has held various technical positions with the Conair Group, including technical services manager, product manager and business unit manager. He now has his own consulting firm, Polymer Drying Services. Contact: 814-516-3838; pstoughton@comcast.net; pstoughton.com.
Trust the Experts, try Purgex
Change molds faster with Smartflow FasTie Tie-In
Extrusion 2026
Glycon: Run with the leaders in High Performance
You Make Better Products
Imperial Industries welded resin storage silos
Sponsored
High-Precision Auxiliaries Suited for High-Volume Applications
Moretto offers a full suite of products, engineered with the same precision required for those running technical parts at very small volumes, to processors that run at the top end of the capacity scale.
Sponsored
Finding Efficiencies in How Components Work Together
Sponsored
How Vacuum Drying Is Revolutionizing Plastics Processing
Maguire's ULTRA drying technology uses a compact design for faster processing and reduced energy consumption.
Drying
Streamlined Drying Process Speeds Up Changeovers
NPE2024: Maguire demonstrating increase in productivity possible by vacuum drying.
Experience the Ultimate
