It is hard to believe that we are almost two years out from the onset of COVID-19. There is no aspect of the composites industry that has not experienced the ripple effects of the pandemic, and the ramifications are far from over. Nevertheless we’ve kept moving forward. From recycling to contactless in-situ temperture measurement, progress is being made.
CW took some time to reflect on how far we’ve come in 2021, and what you, our readers, found most interesting. Take a look at the top 10 most-viewed articles of 2021 below:
1. Why aren’t composites synonymous with infrastructure?
Coming in at #1, CW’s Editor-in-Chief, Jeff Sloan delves into a topic that is garnering a lot of attention in the U.S.: infrastructure. Under the Biden Administration, the U.S. is poised to invest heavily in this end market, thanks to composites materials’ ease of application, strength, durability and corrosion resistance.. Can the composites industry rise to the occasion?
2. Contactless monitoring of temperature and pressure inside composites
Microwire sensors have been around for quite some time. However, there has been a rapid rise in magnetic materials worldwide for a variety of measurement and sensing applications in the past few years. In this article, senior editor Ginger Gardiner takes a look at how magnetic microwires enable contactless measurement of temperature and pressure during cure and in service, and the huge potential it has in the composites industry.
3. Large-format 3D printing enables toolless, rapid production for AUVs
Autonomous underwater vehicles (AUV) are a type of unmanned robotic vehicle capable of traveling underwater without physical connection to or remote control from a human operator. Often outfitted with sensors and/or cameras, AUVs are used in various markets, including defense and ocean-based research. Energy companies have also used AUVs for offshore survey work to monitor existing oil and gas or offshore wind infrastructure, and to investigate areas for new development. More recently, Dive Technologies (Quincy, Mass., U.S.) started 3D printing prototypes of its composite autonomous underwater vehicles, but the AM process soon became the solution for customizable, toolless production.
4. Novel dry tape for liquid molded composites
In this article, CW walks through MTorres’ (Torres de Elorz, Spain) patented dry fiber tapes and automated, high-speed production lines. Optimized for AFP and high resin permeability, the tapes allow infusion of thicker structures, while the production lines reportedly can convert 50K carbon fiber tow or 4800 tex glass fiber rovings at rates five to 10 times faster than state-of-the-art production by current tape suppliers.
5. Out-of-autoclave VBO rear spar, thermoplastic ribs target Wing of Tomorrow
Airbus (Toulouse, France) is in the midst of a broad effort to work with aerocomposites fabricators on the development of out-of-autoclave (OOA) structures for the company’s Wing of Tomorrow (WOT) program. These structures are being delivered to Airbus in 2021 and will be assembled into a demonstrator wing that will be tested and evaluated for potential use in a next-generation single-aisle aircraft. When such a program might be announced is unknown, and the subject of much speculation, but the entire aerocomposites supply chain is positioning itself to be a part of the next generation of aircraft manufacturing, whether it’s for Airbus or Boeing, or both.
6. Wing of Tomorrow ribs: One-shot, thermoplastic, OOA consolidation
GKN Aerospace (Bristol, U.K.) has been very active in the WOT program, including the development of a wing spar demonstrator made via resin transfer molding (RTM) and four aluminum wing ribs. Another technology demonstrator recently delivered by GKN Aerospace involved the development of both a cost-competitive thermoplastic composite rib, and an innovative, modular press system for one-shot, OOA manufacturing to produce it. GKN Aerospace’s carbon fiber thermoplastic aircraft rib design accomplishes 45-minute cycle times, reduced weight and competitive costs via a customized press system.
7. Braided carbon fiber & resin transfer molding for complex composites
In this Digital Demo, Craig Jennings, CEO of Spintech Holdings Inc. (Dayton, Ohio, U.S.), introduces Hawthorn Composites (Xenia) and case studies of its high-value complex composites parts that are developed by deploying low-cost materials with resin transfer molding and novel manufacturing methods.
8. Recycling end-of-life composite parts: New methods, markets
Many composites recycling methods work by burning off (pyrolysis) or chemically dissolving (solvolysis) the resins from a composite part, so that the fibers can be reclaimed and reused. Some promising recyclers and researchers are also working on methods for repurposing end-of-life (EOL) composite parts in their entirety. Reasons include retention of more of the original fiber and resin’s mechanical properties, reduction of processing costs or reduction of the carbon footprint of the recycling process. Associate editor Hannah Mason gives summaries of two such efforts.
9. Advancing the OOA infused wing box
As the aerospace industry recovers from the COVID-19 pandemic, the previous push for high-rate production has pivoted to an urgent drive to reduce environmental threats to the planet and to people. Though these initiatives were ongoing pre-COVID, their emphasis is now heightened, as is the need for much lower cost to produce composite structures. The Clean Sky 2 pan-European aviation program has funded research and development in all of these areas and has significantly advanced a variety of fiber-reinforced composite technologies. Included in Clean Sky 2’s seventh call for proposals is the Airbus Defence and Space request for an innovative and flexible pilot plant to produce a highly-integrated wing box flying demonstrator using automated fiber placement (AFP) and liquid resin infusion.
10. Reprocessable, repairable and recyclable epoxy resins for composites
Started in September 2018, CIDETEC (Donostia-San Sebastian, Spain) began a 42-month project that will advance 3R composite thermoforming processes for high-volume production, cost-effective 3R composite repair and assembly via thermoset welding and improved adhesive bonding. These technologies will be showcased in two aerospace demonstrators: a composite fan cowl section with RTM skin and transverse stiffener adhesively bonded to a thermoformed longitudinal stiffener; and a section of a wing leading edge with thermoformed ribs welded to a skin made using same qualified RTM (SQRTM).
As 2022 begins, we are anticipating a bright future for composites. Along with that brings many opportunities to cover the most innovative aspects of the industry. If you have some of your own ideas about stories or topics we should consider covering, contact Jeff Sloan at jeff@compositesworld.com. We’re always interested in hearing from our audience. Cheers to a great 2022!
PEEK for Monolayer E-Motor Magnet Wire Insulation
Solvay’s KetaSpire KT-857 PEEK extrusion compound eliminates adhesion and sustainability constraints of conventional PEEK or enamel insulation processes.
Read MoreCelanese to ‘Shine’ at CES 2023 with Expanded Portfolio of Materials
With it acquisition of DuPont’s engineering resins, Celanese’s resin solutions for automotive electrification, e-mobility and consumer electronics are plentiful.
Read MoreABC Technologies to Acquire Windsor Mold Group Technologies
Read MoreNew Technology Bonds Aluminum With Polyamides
With many benefits for numerous potential applications, including in the burgeoning electric vehicle market, Celanese’s Zytel Bonding Technology achieves stronger bonds than overmolding or welding.
